Rear Axle Pinion seal
Old Apr 4, 2008 | 10:12 AM
  #11
ctsbob's Avatar
Default RE: Rear Axle Pinion seal
Hi all new to this forum..I have a 07 and the rear pinion seal is a now a GM recall, I was getting a howl at 60 mph so I took it in and they replaced the compleat rear diff under warranty.
Old Apr 4, 2008 | 10:15 PM
  #12
brougham1's Avatar
Was this pinion seal leak not a recall issue, I think I posted the blurb quite some time ago. Check with the Cadillac recall people and make sure you don't pay out of your pocket if it is.
Old Apr 4, 2008 | 10:23 PM
  #13
Underdog's Avatar
I thought this was well known, but I guess not. I purchased a CPO '05 CTS in December. A week later I saw a news story that reported there was a recall on it for the pinion seal. I checked with safecar.gov and sure enough, NHTSA recall #07V589000, GM recall # NO70204 "pinion seal". It said the recall was supposed to start in Feb. I brought the car back to the dealer for a battery replacement and they told me they "noticed" the rearend was leaking and were going to replace the pinion seal under warranty. Well, I know it wasnt leaking because I checked for leaks and fluid level when I first read about it. I told the service advisor about the recall and he said it 's not a recall, its a technical service bulletin. Right. I think they just don't want to call it a recall. I'm lucky, I guess, I still have 3 years and 60K miles left on the warranty. Best of luck to everybody dealing with this issue. Mike.
Old Aug 21, 2008 | 09:04 PM
  #14
mmorgan's Avatar
well i'm new at this and don't check this forum very much. last time i looked there was some hint of rear end problems. after reading this i'm going to check my pin seal. i have an 05 ctsv. it's had a new water pump, the trans has been out three times. two for squeeks, once to be replaced. the trans made a moaning noise at speed and i complained about it, they said that it was normal. two months later they replace it. my car is a garage queen, just over 28000 miles.anyway i'm getting some noise from the rear, but i think.hope, it's just worn tires, it's hard to keep tires on it.
Ludde
Dec 17, 2014 09:45 PM
ctsv2010
Dec 18, 2012 12:28 PM
jordannovotney
Vintage & Classic Cadillacs
Dec 29, 2008 06:57 AM
motor44
Jul 11, 2008 08:05 PM
