CTS coolant question
Old Apr 16, 2006 | 11:36 PM
dirtyleft's Avatar
Default CTS coolant question
hey guys,
i just bouhgt a used CTS 2 month ago. I dont know anything about it. One question i have is the coolent level. everytime i crank it it says check coolant level. then i have to clear the screen. i finally tried to check it today and discoverd that there is no radiator cap. antleast there is not one i can see. Anyone know what i should do?
Old Apr 18, 2006 | 12:46 PM
VetteViperGuy's Avatar
Default RE: CTS coolant question
most likely...get the radiator cap from the dealership and your coolant check will be gone...
Old Apr 19, 2006 | 01:52 AM
dirtyleft's Avatar
No, i do not mean that the radiator cap is missing, i mean that ther is not one present where they usually are. i need to know where it will be if any
Old May 22, 2006 | 02:56 AM
borg100's Avatar
I had the same issue"check coolant" with my 2003 CTS. I took it to the dealer. They told me that there was a hose leak and fixed it.
Old Sep 15, 2006 | 12:00 AM
Cadillac Man's Avatar
If the light is still on go to the dealer they will diagnose the issue and fix it plus you have to get the light reset. well advance auto can do thAT for you.
Old Sep 15, 2006 | 12:49 AM
hagrid's Avatar
On a similar issue, I removed the radiator cap to check coolant level and the coolant sensor. The mechanic diagnosed a radiator hose leak and replaced it.
Old Oct 20, 2014 | 11:12 AM
bg1278's Avatar
There's no radiator cap. There's a reservoir on drivers side with marking to fI'll while cold under the hood.
Old Feb 16, 2017 | 12:17 AM
Mariela Cruz's Avatar
hey i had a question how much did the hose repair cost you? It seems like i am having the same issue causing my engine to smoke, but there are no signs of over heating.. they want to charge me $250 so i just wanna make sure i am not getting ripped off.
Old Feb 16, 2017 | 01:57 PM
This thread is several years old, so I doubt the price would be the same. Start your own thread of your concern; include year and model along with engine size of your car.
sorma03
Oct 4, 2012 10:58 AM
cady97dev
Aluminum Block V8s
Mar 20, 2009 08:10 AM
Underdog
May 7, 2008 08:31 PM
