Climate control temperature control stuck on 90
Old Nov 20, 2016 | 06:21 PM
pinebear's Avatar
Default Climate control temperature control stuck on 90
Both sides driver and passenger side stuck on 90 degrees and can not move. Plenty of hot air coming in on the vents when automatic is turned on.
What can it be ? just the switch or controls or what?
Old Nov 21, 2016 | 02:10 PM
You could disconnect battery and see if it resets to seventy five. If it does the by pressing temp buttons you migh determine if it's related to buttons. If not I think you will need a tech2 scanner
nickhess
Oct 12, 2010 05:49 PM
dray5mil
Dec 20, 2008 01:18 PM
2000ESC
May 31, 2008 07:21 PM
carl.r.johnson
Sep 18, 2007 01:46 PM
lenny lincoln
Apr 17, 2007 09:17 PM
