2010 CTS 4 reduced engine power service traction control after car wash
Old May 12, 2020 | 11:11 AM
Towman's Avatar
Default 2010 CTS 4 reduced engine power service traction control after car wash
Everytime after I run my car through the car wash it goes into reduced engine power and service traction control. I recently had the timing chains, tensioners, cam sensor oil change and was running great. After that both times I washed my car this happened. If I let it sit for a couple of days it goes away. Anyone have a a suggestion as to how I can Solve this issue??? Any suggestions would be greatly appreciated
Old May 19, 2020 | 05:28 PM
KGMtech1's Avatar
Most likely one or more wheel speed sensors or their wiring is causing a problem. I don't think any of the other engine work done would be related to the new issue. Check the wiring of the 4 wheel speed sensors, or have the car scanned, the specific wheel speed sensor will be noted as the source of the problem. That it goes away when things dry out indicates a bad wire or bad ground somewhere.
Des324
Oct 7, 2018 08:45 PM
Des324
Oct 7, 2018 08:35 PM
enzo
Jul 26, 2017 01:32 PM
pinky1080
Mar 31, 2017 11:46 AM
jpmatia
Dec 19, 2008 01:54 PM
