2008 CTS will not shift to drive
Old May 16, 2011 | 10:22 PM
Daale002's Avatar
Default 2008 CTS will not shift to drive
I can't get my 2008 CTS to shift into Drive. Will shift from park to reverse and to neutral but that's it. The shifter seems to be in the drive cause I can get it to go into drive low and high,but nothing happen. It stay in neutral.
Old May 17, 2011 | 07:55 AM
gmtechs's Avatar
check cable
Old May 17, 2011 | 08:39 AM
Daale002's Avatar
No cable,just a rod from shifter to transmission lever. Looks good no damage noticed. This is a 2008 model with the mx0 tranny.
Old May 17, 2011 | 06:51 PM
gmtechs's Avatar
is the lever hard to move like its locked in place
or is it u go there and vehicle does not move
Old May 18, 2011 | 04:47 AM
Daale002's Avatar
Lever is hard to move out of park and I can't get it to go into Drive. Indicator show P,R and N and the tranny actually going in to this gear,but not into Drive. When in Neitral the shifter is all the way out.
Seems like it has come out of ajustment.
Old May 18, 2011 | 05:55 PM
gmtechs's Avatar
if possible have someone shift it while u r looking at the rod and see how it moves
Old May 19, 2011 | 09:19 AM
Daale002's Avatar
I've done
this and it moves. What would I be looking for. Do you know if there are some adjustments and or measurements to take?
Old May 19, 2011 | 08:29 PM
gmtechs's Avatar
well u can move it from under car i just trying to figure out is it in the tranny problem
or inside tranny
u can take the rod off and manual move it if it moves it a external problem but if it does not go in then its an internal problem
Robnsteal91
Mar 17, 2013 01:42 AM
beddism-caddy
Feb 22, 2009 03:10 PM
85flhtc
Feb 1, 2009 03:51 PM
88coupedeville
Aug 1, 2008 09:57 AM
l306x
Automatic Transmissions
May 13, 2007 01:38 PM
