2004 CTS No brake lights issue....need help please.
Old Sep 3, 2017 | 10:49 PM
flyin99's Avatar
Question 2004 CTS No brake lights issue....need help please.
Helping a friend with his son's 04 CTS......has no brake lights........bulbs are new.......switch at pedal is new......fuses checked OK.........removed rear seat and found the relay........doesn't "click" when hitting brake pedal, but if you jump it with 12V jumper wire, the relay "clicks" and the brake lights come on. Where do we need to go from here? It seems as though the trouble is in front of where we're looking......anyone have a diagram of the wiring to the switch and back to the relay? All we can find is from the relay back. Thank you all!!
Old Sep 4, 2017 | 10:26 AM
flyin99's Avatar
Todays find........not getting power to the brake pedal switch.......what powers this fella?
Old Oct 18, 2017 | 05:19 PM
Ridgediva1's Avatar
Default Same problem.
Hello,
I'm having the same issue with my brake lights. Were you able to solution?
Old Oct 19, 2017 | 04:52 PM
flyin99's Avatar
Originally Posted by Ridgediva1
Hello,
Yes but you probably won't want to go the route we went. ....Took out the brake switch sensor above the pedal......installed a bracket, holding an old style brake light switch, from a early 70's truck.....ran 12 volts to it and boom! Brake lights now work
woody2846
Nov 20, 2010 04:10 PM
Cadillac Al
Jun 1, 2009 11:14 PM
jdash
Jul 17, 2008 09:18 AM
celishorn
Jul 13, 2008 10:32 AM
FleetwoodGeorge
Nov 8, 2007 11:25 PM
