Timing cover oil-leak
Old Jun 1, 2008 | 08:07 AM
Dave S Texas's Avatar
Default Timing cover oil-leak
I've put off this oil-leak project a long time, but now I'm going after it. I'm fairly certain all the components can be gotten to from the RH wheel-well. I'm uncertain about what gaskets I'll need to replace, other than the Timing-cover gasket? Can the oil-pan gasket be changed without pulling the engine? I first intend to degrease the area, check for loose fasterers and then flour-spray the area. If, after that, a leak shows, I'll dig into it further. Hopefully I won't find the dreaded cam-shaft block-split problem. Any advice is appreciated, thanks.
Old Jun 12, 2008 | 10:05 AM
Big5DoubleZero's Avatar
Default RE: Timing cover oil-leak
What year and which engine?
Old Jun 12, 2008 | 02:10 PM
Hello....thanks for the response. 1987 Coupe DeVille/FWD/4.1L
Since I posted this, I know more. Cleaned the engine and found no leaking from the TC cover areaor from the oil-filter adapter. The leak is from the rear-main area. Unfortunately fixin' this requires removing the transaxle. No experience with that and it's kinda intimidating not knowing.....
Old Jun 12, 2008 | 10:47 PM
Yeah doing a rear main on a FWD vehicle can be intimidating without proper equipment.
I will give you a few numbers for gasket sets from Fel-pro if you find more leaks.
Rear main seal - #BS40396 (one piece)
Timing cover set - #TCS45522-2
Oil pan - #OS30525T -> premium set
Oil Pan - #OS30525C -> general cork gasket set
If ya need any others let me know.
td25
Feb 13, 2011 07:11 PM
mattmondo
Sep 17, 2010 08:41 PM
cadillac93pimpin
Apr 7, 2009 02:39 PM
lferrebee
Aug 23, 2007 04:36 PM
0rion
Mar 6, 2006 12:44 PM
