Engine troubles
If it has a points distributor, then verify the dwell is at 30. Backfiring underhood is usually either timing, or dwell incorrect or a worn accelerator pump in the carb. Could be a clogged fuel filter but unlikely. The filter in the carb will by pass if restricted.
