bypassing the ABS
Old Nov 8, 2009 | 10:36 PM
tobyed's Avatar
Default bypassing the ABS
Hello,
I am building a project using a complete 97 Seville motor and wiring harness. My problem is that I do not really want to use the ABS system or the electronic suspension system. Is there anyone with any knowledge of what I may run into if I try and delete the wheel sensors, or "trick " the computer by some other means?. Thanks for anyones help.
P.S. if it matters, the transmission is a F40 6 speed manual
Old Nov 28, 2009 | 01:44 PM
anypeassiff's Avatar
Usually it is the Brake light and not the ABS light that should come on when your low on fluid.
Old Nov 28, 2009 | 07:02 PM
Originally Posted by anypeassiff
usually it is the brake light and not the abs light that should come on when your low on fluid.
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
ruaskier2
Oct 5, 2006 02:59 AM
gunkscad
Sep 17, 2006 11:00 AM
gunkscad
Aug 22, 2006 11:22 PM
onecool
Jul 10, 2006 03:23 PM
