brakes
Old Mar 26, 2007 | 01:21 AM
obosse's Avatar
Default brakes
I have a 2001 deville and i get a display on the dash that says, ABS also Traction Control .what should i look for. I am also getting low coolint now also! I checked the watter level it is fine, any ideas! thanks
Old Mar 26, 2007 | 01:44 AM
Katzmans Caddy's Avatar
Default RE: brakes
You could have a bad ABS sensor. The Traction Control system utilizes the ABS braking to keep the drive wheels from breaking traction. I am assuming you are not standing on teh gas and burning rubber when this happens because when you do that the TRACTION ENGAGED will display.
For the LOW COOLANT again it could be a badsensor.
Old Mar 27, 2007 | 08:51 PM
obosse's Avatar
Default RE: brakes
How do i check out the ABS sensors? And the coolent sensor! Thanks in advance.OB
Old Mar 31, 2007 | 05:26 PM
SGTFDA's Avatar
Default RE: brakes
I had the same thing happen yesterday. I replaced the back brakes on my 96 Cad. and both the ABS and tractionlight came on . I had knocked the wiring plug out of the back of the brake assembly on one side. I jacked the car up and put the plug back in and the lights went off.
Old Apr 4, 2007 | 09:48 AM
belagatyo's Avatar
Default RE: brakes
ORIGINAL: obosse
Similarly, a loose or corroded connection might result in the COOLANT LEVEL warning. Check/clean/reseat the connector, and if that does not clear up the situation, the sensor itself is the culprit.
phyunescalade
Feb 23, 2007 05:44 PM
brian_hobbs
Nov 18, 2006 12:41 AM
ruaskier2
Oct 5, 2006 02:59 AM
tuttibear
Jul 29, 2006 01:04 PM
donny54
Jun 22, 2006 09:54 PM
