Bearing size on a 429 1966 Cadillac Coupe de Ville
Old Jun 7, 2008 | 05:36 PM
Brandon2396's Avatar
Default Bearing size on a 429 1966 Cadillac Coupe de Ville
I am going to rebuild the 429 on my cadillac and in order to do this I need the bore size which I know and the bearing size. I'm not sure how to find this. If anyone has the info I'd greatly appreciate it.
Old Jun 12, 2008 | 09:40 AM
Big5DoubleZero's Avatar
Default RE: Bearing size on a 429 1966 Cadillac Coupe de Ville
My Sealed power book lists these numbers but not the sizes of the bore.
Main bearing set - #4419M
Rod main bearing set - #8-2120CP
Cam bearing set - #1216M
The rod & main setscome as Std or10, 20, 30 oversized if you have had the crankshaft reground.
The cam bearings are just standard OEM replacement. If you go through a store that sells different brand just have these numbers cross referenced.
Old Jul 7, 2008 | 06:12 PM
Thanks for the info.
moobymuffin
Jun 16, 2011 11:53 AM
alwcurlz
Big Block V8s
9
Jun 23, 2010 04:05 AM
moobymuffin
Mar 4, 2009 02:05 AM
zzbog
Apr 12, 2008 12:12 AM
r1volta
May 20, 2007 08:22 AM
