Bearing size on a 429 1966 Cadillac Coupe de Ville
I am going to rebuild the 429 on my cadillac and in order to do this I need the bore size which I know and the bearing size. I'm not sure how to find this. If anyone has the info I'd greatly appreciate it.
RE: Bearing size on a 429 1966 Cadillac Coupe de Ville
My Sealed power book lists these numbers but not the sizes of the bore.
Main bearing set - #4419M Rod main bearing set - #8-2120CP Cam bearing set - #1216M The rod & main setscome as Std or10, 20, 30 oversized if you have had the crankshaft reground. The cam bearings are just standard OEM replacement. If you go through a store that sells different brand just have these numbers cross referenced. |
Thanks for the info.
