transmission supports necessary
Old Aug 1, 2019 | 07:27 PM
john yerxa's Avatar
Default transmission supports necessary
Hi I have 1979 Cadillac deville 425 and installed dual exhaust back from the back of the headers. The cross member between the frame rails holding up the transmission only has one hump so had to cut the other side and weld in a piece of pipe for exhaust pipe to pass thru. When building and bending the pipe on that side, we had to remove another tranny support bracket to make room and didn't reinstall. The mechanic said a lot of people do that.
My question is will that make my transmission less stable and may tend to vibrate when under throttle thus causing the drive shaft to not turn nice and level.
especially when I step on it for power and torque.
Thanks.
Old Nov 2, 2019 | 01:36 PM
Short Fuse's Avatar
The cross member does need to attach to both sides.
brian29
Aug 20, 2018 08:21 AM
YoungBlood1034
Dec 20, 2016 06:01 PM
OldsD88
Cadillac Allante 1987 to 1992 Phase I & II
Nov 3, 2009 03:36 PM
89whitefleet
Oct 23, 2008 01:33 PM
ledetrljr
Cadillac EXT
May 18, 2007 08:37 PM
