TCC Solenoid
Old Apr 18, 2012 | 02:34 PM
  #11
Adams' Apple's Avatar
Originally Posted by funbunch
@Adams Apple
Thank you for assisting with the trans trouble I wrote about a couple weeks ago.
1998 Seville STS
To summarize, P0741 code (and a few other trans related codes) appeared (about after the time I changed out the high pressure PS hose) and the trans was in single shift - emergency mode.
Took it to a dealer (Stevinson Chev - Lakewood, CO) for confirmation of the bad news - an overhaul was assumed.
The fluid was clear and no shavings were found.
I had not taken up the slack in the PS hose sensor wiring, and it's rubbing on the drive shaft caused a bare wire.
The transmission and the PS hose electrical are on the same circuit. A blown fuse caused the transmission to go into it's fail safe mode.
A hundred dollars for: the inspection, dropping the pan and changing fluid and filter, and a 10 A fuse
Glad you got it taken care of without a rebuild! You didn't mention any other codes in your original post. Power for the shift, and lock-up solenoids are on a separate circuit from the EPC solenoid, but a bare wire(or 8!) can definitely ruin your day!
Old Apr 18, 2012 | 02:42 PM
  #12
Originally Posted by NewToGM
I have a question about that also, I have a 1994 SLS that gets code P039 past about 45 and it turns off under.
I know I need to flush the trans and install a new filter but did the 94 have a TCC? If so is it under the trans oil pan like other models or inside the trans?
Does the TC on a 94 have a plug to drain it or will I need to have it flushed by someone?
Again...P039 is still a Torque converter slip code. Still a problem with the 4T80E trans. I don't recommend flushing a trans, ever, but that's just me. The TCC solenoid is inside the side cover...not accessible very easily at all.
CIRCUIT DESCRIPTION
The Torque Converter Clutch (TCC) solenoid controls the hydraulic fluid for apply or release. The diagnostic test checks for a torque converter clutch not engaged or slipping condition by monitoring the slip speed. Slip speed is the difference between engine speed and transaxle turbine speed. When the TCC is applied, the engine is coupled directly to the transaxle through the TCC. Almost no slippage should occur, so the slip speed is nearly 0. If rpm is too high at a given speed, the Powertrain Control Module (PCM) diagnosis the condition as the TCC slipping or not engaged and Code P039 is set.
TEST CONDITIONS
  1. Codes P024, P026, P027, P028, P031, P032, P034, P056 and P075 not set.
  2. Transaxle in 3rd or 4th gear.
  3. Engine running.
  4. TCC commanded "ON" (100%).
  5. Transaxle not in park or neutral.
  6. Throttle position switch open.
  7. Delivered torque from engine not 32 ft lb or less (coast down condition).
  8. Delivered torque from engine not 508 ft lb or more (engine under extreme load (Example: towing a trailer or wide open throttle).
FAILURE CONDITIONS
3.71 Final Drive (VIN 9) - Slip speed 48 rpm or greater for 4.5 seconds.
3.11 Final Drive (VIN Y) - Slip speed greater than acceptable value based on engine torque delivered for 4.5 seconds. Refer to chart in accompanying image for acceptable TCC slip values.
ACTION TAKEN
  1. PCM turns "ON" the Malfunction Indicator Lamp (MIL) (Service Engine Soon).
  2. TCC is disabled for the entire ignition cycle.
NOTES ON FAULT TREE
(Part 1 of 2)
  1. Testing Torque Management Brake Switch input to the PCM PI71. If test passes, the display will change from HI 0 to HI X. If test fails, the display will not change.
  2. Checking for an open in CKT 420 between C129 and C101.
(Part 2 of 2)
  1. Checking for open or shorts inside the transaxle. The resistance should be between 10 and 40 ohms.
  2. Checking if CKT 422 is open or if the PCM is unable to control the output.
  3. Checking PCM's ability to control the TCC output.
  4. Checking if TCC is operating correctly by checking amount of TCC slip when clutch is engaged.
NOTES ON INTERMITTENTS
Intermittent code P039 setting may be caused by delayed TCC engagement (usually the first apply after a cold start) or by TCC slippage during high engine load conditions. Delayed TCC engagement can be checked using PCM 0utput Override PS01 (TCC Solenoid) to disengage and engage TCC and time how long it takes TCC to engage by watching PCM Data PD73 (Torque Converter Slip Speed). Delays of over 5 seconds may cause the code to set. TCC slippage during high load conditions can be determined by looking at code P039 Snapshot Data. High throttle angle (PD01), MAP (PD02), and engine coolant temperatures (PD04) may indica!e a high load condition. Duplicating the high load conditions may cause the code setting conditions to occur.
Old Feb 27, 2013 | 05:14 PM
  #13
FLASH ME's Avatar
What kind of prices can I expect as far as parts?
Old Mar 15, 2013 | 12:51 PM
  #14
April Blackmon's Avatar
Thanks for this info! I am having the same trouble with my 01 STS. The mechanic I have been using has been telling me that I need to replace the camshaft sensor (this is after i paid him to replace the crankshaft sensors and oil pressure switch and he said the camshaft sensor was fine). He just lost a customer! So glad I found this
Old Mar 21, 2013 | 12:04 AM
  #15
MJ'S AUTO's Avatar
Default Po174
Hello I'm new here, I have a 1996 Cadillac Deville with the Northstar V-8 engine.My wife purchased the vehicle from her uncle for 3 grand against my advice.We had the car less than a month and the transmission out of the blue went from driving good to driving 60mph @ 4600rpm's.I plugged it in and had a code of PO174.I'm needing to know my options before I jump into this job.I called a tranny shop and told them the code and they said it would be about 2800.00 to fix it but didn't give any details of what is wrong.I've done some research and I'm not sure on what to-do.It has the 4T80E Tranny.There is no slip or oder, the fluid is clean and no shavings.Any advice would be appriciated.I'm a mechanic but not a transmission expert.Thanks Guys....
Old Mar 21, 2013 | 12:12 AM
  #16
MJ'S AUTO's Avatar
Default Po174
Old Mar 30, 2013 | 10:01 PM
  #17
PO174 is NOT a transmission related code. It is Fuel trim System Lean on Bank 2. How a trans shop could tell you you need a trans just by that code is interesting.
You may have a vacuum leak somewhere that is causing a skewed MAF, MAP, or other sensor reading that could set that code, and also keep the PCM from commanding the trans into Lock-up, which would cause your higher RPMs.
You might certainly have a trans problem, too, but the code you posted is not enough info to attempt to diagnose a trans problm.
However....if you remember the code incorrectly(or like me, are slightly dyslexic), and what you have is actually a P0741, then we have a different story....are you certain you have a P0174?
Old May 1, 2013 | 10:09 PM
  #18
sawbillbob's Avatar
I drive a 2003 Seville with the 4t80e tranny. The tcc solenoid failed, and I am in the process of replacing by accessing the side panel. Supposedly a clip holds the solenoid in place, but upon inspection, I do not see a clip. The shop manual diagram shows a u shaped clip with a loop that could be hooked. Are there other clips used that do not have the loop?
Old May 7, 2013 | 10:11 PM
  #19
The clip is there...it may be twisted down into the channel where it is hard to see, but it is there. You can get a small screwdriver, or pick in the top part, and pull it straight out. I have posted pics of these things several times here....still looking for them....
If the plastic on the solenoid is melted, or looks burnt in any way, replacing the solenoid might solve the problem for a little while...until the solenoid melts again. The problem that normally causes the solenoid to fail or set a code is actually leakage in the hydraulic circuit for the lock-up. The PCM sees the converter slip, and ramps the solenoid up to try to control the slip, eventually getting to a point to where the solenoid is "ON" all the time, instead of being pulsed on/off(PWM). The solenoid is not designed for that kind of situation, and it eventually gets too hot, and melts.
Old May 12, 2013 | 09:31 AM
  #20
sawbillbob's Avatar
Default tcc solenoid replacement
OK, I just completed the TCC repair on my 2003 SLS with the 4T80E. SES light was on with codes 741 and 1860. It took much longer than expected do to this being my first attempt. A couple critical details could have reduced the process considerably. I took 102 photos and a full page of notes to create my own how-to manual. Before you attempt this just know that the GM engineers designed the transaxle not to be serviced without removal from the vehicle. The upper valve control side cover is positioned pretty much against the frame. Several bolts require stubby wrenches, and the retaining clip is very challenging. And it does get messy, so have plenty of cardboard, drip pans and floor dry handy to capture and control the fluid spills. I purchased my solenoid on Amazon for $30. Transmission shops quoted $1700, but included additional components, like a new torque convertor. The Seville is back together and running without the SES light, so I am calling my effort a success.......for now at least.
