SEville 4.1L Oil Cooler Lines-Help!
Old May 24, 2007 | 10:26 AM
pkared's Avatar
Default SEville 4.1L Oil Cooler Lines-Help!
These seem to have been discontinued, can't find them anywhere. One of mine has rusted through and is leaking too much to drive the car. I need to get these replaced. Does anyone know the threads on the Filter adaptor side and radiator side? Car is at the dealer and I don't have access to it. I wonder if I can use Metal Braided rubber hose with a couple of adaptors?
Old May 24, 2007 | 08:52 PM
brougham1's Avatar
Default RE: SEville 4.1L Oil Cooler Lines-Help!
Pkared: You could probably jury rig some adapters etc and make it work. You could also just buy the right size steel line, a tubingbender,a flaring tool and use your original fittings to make a new line. It will take you bit of time but when the parts aren't available we must improvise. Good luck........................
Old May 30, 2007 | 03:35 PM
pkared's Avatar
I found some other passages that mention Truck repair shops often fabricate lines and can certainly handle this-we'll see. The problem is the lines(As you may know) start out with steel tubing ,(Why it rusted through)a nice flared end with threaded fitting at one diameter, switch to Rubber Tubing that is fastened the way they do Air Cond. Hoses, and then it goes to a larger diameter steel tube with flared end and threaded fitting. That's a lot of jury-rigging when there's high pressure involved-
There's also a place online that has all the stuff to do it :www.discounthydraullichose.com But I wouldn't want to purchase all the tubes for just one job ig I can avoid it. That would be a $500 Coolant line. It is a cadillac though...
nnedrebo
Sep 13, 2015 07:40 AM
greg2169
Jan 28, 2013 04:07 PM
Need4Camaro
Aug 3, 2011 08:14 PM
edgrmndz
Mar 17, 2011 10:35 PM
langeberg
Apr 29, 2008 04:21 PM
