oil pump drive shaft 4.1 Help!
Old Nov 2, 2007 | 07:52 AM
vettemad's Avatar
Default oil pump drive shaft 4.1 Help!
How far does the oil pump drive shaft (hex)stick up from its bore toward the distributor bottom? mine comes up approx.1/4 inch and there's a washer there also taking up some of that space , I fear that it's keeping the pump from operating as I may have forced it in by not having dist. and shaft alinged correctly whean replacing... Pease help asap! thanks, cliff
Old Nov 2, 2007 | 08:24 PM
Default RE: oil pump drive shaft 4.1 Help!
It sounds like its a little low. Washer should be thin maybe .030 thick. If you replaced oil pump - You did install o ring on tube from pump where it goes in to block.
voodoochikin04
Feb 19, 2019 08:14 AM
Texan4Life
Jan 19, 2010 06:15 PM
thezo816
Apr 30, 2009 05:42 PM
jcobz28
Aug 10, 2008 10:15 PM
Nels Sandberg
Jul 18, 2007 08:26 PM
