Need some advice Eldorado 4.6 ETC late 93
Old Feb 2, 2012 | 06:58 PM
ETC93's Avatar
Default Need some advice Eldorado 4.6 ETC late 93
Does anybody know where I can buy a new front windschield molding (kind of black rubber wirh chrome strip in the middle) ? I asked the Roger Penske Ca dealer where the car was bought new but got no answer.
I recently discovered a technical issue, it appeared clearly with the cold weather :
Engine starts fine, slightly hesistating while idle cold
Once I touch the gas pedal, RPM increases up to +/-1400, engine sounds like too much fuel or not enough as if some cylinders do not fire up. Check engine light comes up if running idle for a whike but not when driving until hot.
Once the engine is at normal operating temperature, it runs fine, idle is OK.
I cleared ODB codes by disconnecting the battery.
Afterwards (the engine was still hot), I drove the car and pulled OBD codes :
P052 history (PCM Memory Reset)
P109 history (Keep Alive Memory (KAM) Reset/PCM has lost primary battery power)
The next day : cold start. I drove the car about 3 miles (freezing temperature outside), normal temperature was not reached yet and I had to stop to answer a phone call. I kept the engine running idle during the phone call, the Check Engine light came on. I drove the cas until normal operating temperature. Stopped and restarted the engine : Check Engine went out.
The next day I pulled another OBD code :
P030 history (ISC RPM out of range)
Something else : powerbreak is not very strong
Could this all be related to a vacuum leak ? Is there soething else or in particular I should look at first ? Any expert advice from the connoisseurs will be very much appreciated. Will I find answers in the FSM for this ?
Original mileage: 71.000
utahpaul
Jul 9, 2010 09:45 PM
caddigoes
Jun 6, 2009 09:08 PM
real_ivan_ivanov
May 21, 2009 09:13 AM
gwmcintire
Apr 12, 2007 12:38 PM
TOMMYDeVILLE
Oct 7, 2005 08:04 PM
