Head Bolt Stripped
Old Aug 23, 2007 | 12:42 PM
srchapman's Avatar
Default Head Bolt Stripped
I have a 92 Deville w/4.9. My Hays repair manual states that the head bolt torques are as follows: 1st pass 38 ft/lbs, 2nd pass 68 ft/lbs and 3rd pass on #1,3 and 4 to 90 ft/lbs. I started out torqueing 1st 35ft/lbs, 2nd 48 ft/lbs and 3rd 60 ft/lbs. (I was looking at the wrong chart) but regardless the #1 head bolt stripped out before getting to 60 ft/lbs. I need advice in 2 areas here. First I was told I could repair the block with a 12 x 1.75 heli-coil kit with the original head bolt. I called Timeserts and theysaid I would have to payabout $350 for a kit that has 10 inserts with it. I am hoping that the heli-coil will work? Then second I need to verify the correct torque specifications for my 92 model Deville with a 4.9 motor. Thank You for your help.
Old Aug 23, 2007 | 02:27 PM
G.A.R.Y.'s Avatar
Default RE: Head Bolt Stripped
I don't have the torque specs, but the heli coil should work fine.
bigdawgcadillac
Feb 24, 2010 12:10 PM
andrew61987
Feb 25, 2009 11:22 PM
cessnatech
Dec 9, 2008 09:35 AM
CaddyKid
Aluminum Block V8s
Nov 15, 2008 11:09 PM
Richygot1
Aluminum Block V8s
Sep 6, 2008 12:37 PM
