98 sls running hotter than normal
Old Nov 9, 2009 | 11:08 AM
  #11
Originally Posted by majbarron
Yes had rough idle when water was leaking in cyl. Not now. Mine leaked bad enough it caused engine to have so much force on it that it broke the teeth on starter.
coolant is not compressible and if the only thing that broke is the starter's teeth, you were lucky. what often happens when a cylinder fills with coolant fluid is a bent rod or even worse.
this engine needs to be pulled and fixed .. unless it is not an economical repair based on the value of the car, you can always try the $100 in-a-can fix that may, MAY, get the car a year or two of extra life.
The tablets from gm were designed to repair head gasket leaking. Call chevy dealer and ask for coolant seal tabs.
that is not a correct statement. please read the thread in our FAQ ...
Old Nov 9, 2009 | 04:51 PM
  #12
99STSGUY's Avatar
Yes there is a drain plug, on driver side bottom of rad. If you look undr car under rad strait up, you should see thru a hole in metal under covering a plug on the bottom of rad. the hole is big enough to use some pliers or something and twist off the plug...then go from there.
tonyp56
Sep 12, 2021 10:07 PM
majbarron
Nov 4, 2009 08:11 PM
tn350
Apr 9, 2007 11:42 AM
Brupar
Nov 2, 2006 11:36 PM
