humming noise coming out of speakers
Old Feb 9, 2008 | 01:38 PM
1989 fleetwood's Avatar
Default humming noise coming out of speakers
I have pioneer speakers installed in my car. For the past 6 months there seems to be a humming noise coming out of the speakers. Its when im driveing and the noise varys with speed. As i go higher in rpms the humm goes louder. and vis versa. I did some research and found out i should check the ignition system noise suppression devices. But what in the world are those?
Old Feb 9, 2008 | 06:45 PM
BigOLak's Avatar
Default RE: humming noise coming out of speakers
Skip the ignition system and check all speakers for ground issues. Also if you are using an amp try to separate power wires from signal wires (i.e power down driver side and signal down passenger). It really sounds to me like a ground problem.
Old Feb 9, 2008 | 09:07 PM
ORIGINAL: 1989 fleetwood
in simple terms, capacitors / noise filters.
you probably only get it when using the AM band, and to a lesser extent the FM,
next to nothing with a CD / tape player, right?
Old Feb 10, 2008 | 02:09 PM
I only use the fm and cd player ususally, and it humms on both settings.
jeanie2002
Jul 19, 2012 12:49 AM
ranchlady7
Nov 19, 2011 09:46 AM
99STSGUY
Aluminum Block V8s
Feb 5, 2011 12:32 PM
mechanical man
Oct 1, 2008 02:22 PM
1997caddy
Mar 1, 2006 02:47 PM
