2000 DTS Overheating
Old 05-04-2013, 03:41 PM
ccnp6425's Avatar
Question 2000 DTS Overheating
I have a 2000 DTS that I am at my wits end with.The car started to overheat while in stop n go traffic about a 2 weeks ago. Since then I have had the cooling system flushed, replaced the thermostat,water pump and had the radiator replaced.The radiator was replaced by a shop that only specializes in Cadillacs. They tested the cooling system twice for carbon monoxide to see if the head gasket was bad and the car passed both times.Today I took on the highway and it was fine the entire time that I was on the highway. After I was off the highway for a few minutes the car started to heat up again.I also disconnected the purge line from the surge tank after I got the cooling system was flushed and I had a slow steady stream of coolant coming out.Does anyone have any suggestions ? Should I let the car run for a few minutes when checking the purge line to make sure that coolant is constantly flowing >
Old 06-22-2013, 02:05 AM
George Rucker's Avatar
I've got the same problem Chasing a gremlin.. Have dropped $$$ on this.. Dealer found 1 leak in Heater system valve, replaced.. that was a quick $500.. Any educated guesses besides head gasket??
marlow.bailey@gmail.com
06-27-2023 12:22 PM
GWilson
04-05-2015 01:28 PM
rannunziato
02-01-2015 11:51 PM
ccnp6425
05-04-2013 04:49 PM
AlMunoz
Aluminum Block V8s
12-16-2010 06:54 PM
Quick Reply: 2000 DTS Overheating
