turn signal flasher
turn signal flasher
i have a 93 seville sts and my turn signal is acting up. sometimes it wil work and sometimes it wont. also, it sometimes works for a good three or four clicks and then it goes out. is this my flasher? any advice will be helpful.
thank you
thank you
RE: turn signal flasher
could be the switch itself that u push to turn, maybe wiring gettin loose, maybe a loose bulb in the ballast of the flasher, maybe something is wrong with the relay module, you might just have to use a multimeter to see if loose wiring or a relay is the problem. could be many things
hope this helps :
http://search.ebscohost.com/Communit...3&return=y
hope this helps :
9treseville
12-06-2008 10:35 AM
