Sponsored by:
Sponsored by:
recurring E 030 error
Old 05-20-2011, 08:54 AM
mgmcdot's Avatar
Default recurring E 030 error
I have a '91 Seville and replaced ISC motor to fix E030. Replaced ISC 2 additional times, have also replaced TPS, ECM, and distributor rotor. Continue to get same error. Checked for proper Cruise control function and replaced all vacuum lines around throttle body, can't find any binding in cables. Recently installed new muffler and a week later error became more persistent. RPM's are too aggressive in gear and in idle. High RPM's cause down shifting to thump. I can tap the accelerator at stop light and idle will often reduce to normal level. Replacing ISC motor fixes problem temporarily but is not addressing the issue. Any suggestions would be helpful.
prarieboy
01-14-2020 02:50 PM
brick
03-06-2007 12:08 AM
brick
03-01-2007 12:21 PM
madsyd24
06-28-2006 03:51 PM
cncwhiz
12-01-2005 03:36 PM
Quick Reply: recurring E 030 error
