Outside air temp sensor not reading correctly
Greetings,
OK, so I am new to Cadillacs and this site, and I am about to double post, but nobody answered my other post.
. If you need to move this, please do.
Two weeks ago I purchased a 2003 DeVille DTS.
I noticed the outside air temp sensor is off on the plus side by 20 degrees and tends to go down to withing 10 degress of the actual temp as I drive.
All I can think is that the sensor is bad. It is not broke, It is clipped in the correct place in front of the radiator.
It is only a $24 piece. Will I be assuming correctly if I think the sensor is bad?
I saw other posts with suggestions about this, but no answers as to the fix.
Thanks a bunch
Thanks a bunch
RE: Outside air temp sensor not reading correctly
ORIGINAL: skippyDTS
Greetings,
Thanks a bunch
Greetings,
Thanks a bunch
if nothing happens, get a new one.
The sensor remembers what the last reading was when the key was shut off. If overnight, then the reading will be wrong until the car is driven a certain distance above 25 mph. Then it changes either up or down to a more accurate reading. Throughout the day, running errands, the outside temp remains fairly constant so a grossly low or hi display will not occur. This morning my display showed 72 degrees but it was approx. 55 outside. After 3 miles it corrected itself. It will also hold a temp reading in slow moving traffic so as to not record a hot exhaust from the car 10 feet in front of you. This logic is programmed into the PCM.
10-17-2016 08:42 AM
