Sponsored by:
Sponsored by:
90 Deville stalling
Old 03-15-2008, 04:42 PM
FPASSE2's Avatar
Default 90 Deville stalling
Filled the tank and put some dry gas in, but the engine still stalls. No new codes. Stalling occurs at any time without warning. It seems as if the engine just cuts out.
ECM parameters all seem good. But I noticed when I do th ECM override for the ISC motor with cooler button (engine on) (ISC is supposed to retact to base idle) the engine stalls.
Does this mean the ISC motor is bad ? or something else?
Is there any other way to test the ISC or the cam sensor(hall switch) on the car?
How difficult is it to get to the cam sensor switch? Does the distributor shaft have to be pulled?
Old 03-15-2008, 07:34 PM
carnut's Avatar
Default RE: 90 Deville stalling
Stalling at base idle usually means either the base idle is too low or more common, the intake needs cleaned of deposits. Did you research the crank angle sensor threads?
FPASSE2
03-16-2008 01:55 PM
FPASSE2
03-13-2008 06:55 PM
jpr1978
01-20-2008 08:50 AM
nauc
05-11-2007 10:00 PM
shadow
12-23-2006 02:51 PM
Quick Reply: 90 Deville stalling
