Sponsored by:
Sponsored by:
2001 cadillac dhs over heating problem
Old 06-19-2011, 12:38 PM
92_Daddylac's Avatar
the catalytic converter doesnt block any cooling passages. If it does have build up the car will feel a little powerless. If it gets bad enough it wont run hardly at all and go into LIMP mode where you run on 4cyl. and have little to no power then. Is there a check engine light on? Pull the codes if you can. the auto parts stores sometimes have the tool and do it for free. If the carhas had the headgaskets replaced along with all the other parts and still over heats you may have cracked heads. they should have checked this when doing the headgaskets so im going to assume you dont. Also check to see that the radiator fans are working that will also cause the car to overheat especially when in town in slow traffic. Let us know what you come up with and well go from there.
rod67rsz
01-16-2016 01:42 PM
markbowman3
08-26-2011 10:39 AM
hollywoodj10
12-07-2008 10:51 AM
ryanh_3
03-01-2006 02:48 PM
ryanh_3
07-13-2005 10:13 PM
Quick Reply: 2001 cadillac dhs over heating problem
