Sponsored by:
Sponsored by:
1997 cadillac devile not firing
Old 04-21-2009, 03:14 PM
Montek's Avatar
Default 1997 cadillac devile not firing
I have a 1997 Cadillac deville,,,,,
im getting a PCM code P1376
this started after the wiring in the plug that plugs in the coil pac from the PCM was pulled free,,,I though we wired it back the same,,,obviously not,,,it will fire briefly if I disconnect the battery then hook it back updoesnt run but fires briefly then nothing
any thoughts
Thanks
Old 04-26-2009, 01:38 PM
ActionJackson4205's Avatar
The code is Ignition Ground Circuit Fault. So with what you said about the plug it sounds like it's wired wrong.
Old 04-27-2009, 12:45 AM
ditto ...
2002deville2002
04-28-2012 05:26 PM
6pucker
04-25-2011 09:16 PM
Frank
05-08-2009 09:29 AM
wdicus
10-01-2008 10:48 AM
medieval_cadi
10-01-2007 08:23 PM
Quick Reply: 1997 cadillac devile not firing
