1997 cadillac devile not firing
I have a 1997 Cadillac deville,,,,,
im getting a PCM code P1376 this started after the wiring in the plug that plugs in the coil pac from the PCM was pulled free,,,I though we wired it back the same,,,obviously not,,,it will fire briefly if I disconnect the battery then hook it back updoesnt run but fires briefly then nothing any thoughts Thanks |
The code is Ignition Ground Circuit Fault. So with what you said about the plug it sounds like it's wired wrong.
ditto ...
