4.1 engines
4.1 engines
Is it true you can eliminate most of the problems on it by putting a hight voltage dist and wires with bosch plugs. Because they tend to carbon up using original? Did they have a valve problem that you have to use motor honey in it? Minew is popping through carb and code says rich mixture.
also, there are several versions of 4100 engines, so year made is important.
Cadillac Allante FAQ
10-15-2008 10:33 AM
Aluminum Block V8s
04-26-2008 02:36 AM
mr_udy
01-13-2007 07:27 PM
