Brakes leaking near master...88 Brougham
Old 01-07-2008, 02:48 PM
CrusinCaddy83's Avatar
Default Brakes leaking near master...88 Brougham
On my 88 Brougham, The brake line is seeping fluid right where the break line makes a 90 degree bend before it leads behind the firewall. Has this happened often to anyone? I was wondering if it is possible to bypass that 90 degree angle and run either a chunk of brake line or some brake hose to fix the leak without the angle.
Old 01-07-2008, 05:54 PM
Default RE: Brakes leaking near master...88 Brougham
If brake line is broken, many times replacement line is hand formed. Normally means no sharp 90 degree bends.
Old 01-07-2008, 07:30 PM
I am not sure what line we are looking at but if you have a metal line, a rubber line would not be advisable, not on brakes. if it leaks, it needs replacing. usually its the fitting, but sometimes the tube wall does get damaged or even rust. if yours has a flat bent, i be replacing it.
as slowroll eluded to, hand bent lines can be custom bent .. but be carefull of poor quality bends with kinks.
should you need to "BEND" a metal line, get to HomeDepot and spend $10 on a tube bender that will make a good quality bend.
Mack McCullough
04-06-2015 01:30 PM
90FLEET
11-24-2007 03:01 PM
Katzmans Caddy
Vintage & Classic Cadillacs
9
07-11-2007 11:32 PM
zamboni46
04-04-2007 10:09 AM
eaf
10-13-2006 11:19 PM
Quick Reply: Brakes leaking near master...88 Brougham
