2007 escalade Front brakes are locking up..
please help.. PLEASE.. my front brakes are locking up.. I cabbages everything possible,.. brake booster, master cylinder, brake pressure switch front calipers , hoses.. it's still happening.. can anyone please help??? PLEASE..
Cabbages? Any warning lights (abs)? If you have changed all these parts and problem still exists; IMO you need a professional to look at it. If something other than DOT 3 brake fluid was used that could be cause.
Sorry about cabbages?? Spell check..
I think he put in dot 4.. so can i bleed the brakes or flush then and put in dot 3?
Most DOT4 is compatible with DOT3, DOT5 is not. I still think you need a qualified person to look at it and advise you of what to do. IDK if flushing fluid will help anything. ABS should keep brakes from locking. If rear brakes aren't working that could cause front brakes to lock up.
sgraham
02-10-2010 11:29 AM
chowns5
01-25-2009 01:30 PM
