99 eldorado leaking antifreeze
Am leaking antifreeze and have taken it up on the ramp to see if I could find the source. I can see it isn't from the radiator and looks like it is coming from the water pump. Now this isn't a drip drip drip leak but rather a few drops here and there but seems to be at a pace where after 4 or 5 days it requires some antifreeze added. Can anyone give me some insight as to whether this is something I should get changed quickly. And with that in mind, does anyone know how difficult it is to change the water pump? Thanks.
RE: 99 eldorado leaking antifreeze
Any leaks of any fluid should be attened to quickly. You need a special tool to change the water pump otherwise you risk breaking the aluminium block. I had one changed by the dealer under extended warranty and I saw the bill, $240 two years ago.
