POWER STEERING ASSIST PROBLEM
Old 11-17-2007, 10:33 AM
charlieb's Avatar
Default POWER STEERING ASSIST PROBLEM
I have a 2000 DHS. The power steering assist is not working. I had the system flushed but no luck. I read that the solenoid for the PS assist is fused. I'd like to check that before I replace the rack and pinion. Does anyone know where the fuse is located? Thanks!
Old 11-20-2007, 09:28 PM
Default RE: POWER STEERING ASSIST PROBLEM
Do you have warning message on DIC?
Old 11-21-2007, 06:02 AM
charlieb's Avatar
Hi. I probably do, but I haven't run the diagnostics. I'm just going by the symptoms, hard steering below 1000 rpm. Otherwise, the steering is responsive and tight. Will the DIC narrow down the problem? I'll run the OBD and see if there is a code. Thanks!
Old 11-26-2007, 07:16 PM
charlieb's Avatar
I'm back, finally. Happy Thanksgiving.
No warning display, no C codes. Just living with it now. Not too troublesome. I've been reading up on changing the rack. We'll see...
ccogliandro
11-16-2021 05:49 PM
ccogliandro
03-28-2021 06:02 PM
bum
08-29-2010 09:08 AM
ccogliandro
08-06-2008 04:16 PM
Quick Reply: POWER STEERING ASSIST PROBLEM
