my deville is overheating also
Old Nov 20, 2007 | 01:24 PM
tintman's Avatar
Default my deville is overheating also
Hello , I have a 2000 deville that is overheating , took it to the dealer .
Dealer put in new thermostat and coolant flush . Still overheating
They say exhaust gases mixing internally .Took car home and it overheated
in 10 miles . What should i do thanks for any info. Car has 92,418 miles is my
wifes car we bought it with 41,000 miles on it and drive it about 12,000 miles a year
. Had vapor test done by local shop he confirmed that vapors in antifreeze and in exhaust
with tester
Old Nov 20, 2007 | 01:37 PM
Default RE: my deville is overheating also
ORIGINAL: tintman
with tester
vapors? what vapors? exhaust gases ?
what are we talking about?
it really sounds like your gasket kissed it good bye.
1. change gasket - for long term
2. do the "pour the seal" into coolant system - for unk duration.
http://www.rxauto.com/
this is what happens when the COOLANT is not changes every TWO YEARS.
EVERYONE, forget GM and the 10 year thing, play it safe, change it every TWO YEARS!
Old Nov 20, 2007 | 01:53 PM
tintman's Avatar
should i do the gasket and what is rough price to do so .The test he did
showed that exhaust gases were present in anti freeze . Blue liquid in device turned yellow
he said head gasket .
Old Nov 20, 2007 | 08:21 PM
Cost 22-30 hr and roughly 300.00 in parts.
Old Nov 21, 2007 | 12:46 AM
ORIGINAL: tintman
should you? THAT is your decission to make.
or choice #2 above ?
or choice #3, dump the car ?
Old Nov 26, 2007 | 10:32 PM
96concours's Avatar
I am having the same problem. I just bought mine knowing it had the problem. I think that it is a head gasket. I will start diving in and see what is wrong with mine.
Old Nov 27, 2007 | 05:19 PM
Sicks's Avatar
i just got mine from my brother, 98 deville w/202k miles, and it's overheating too. i'm figuring do a coolant flush anyway cause lord knows he didn't keep up with maintenance, but when i replaced the starter the other day, i noticed about a 1/4 qt. of oilhad collectedunderneath the intake manifold in that lil' valley between the heads. think the head gasketsare related to both overheating AND leaking oil?
Old Nov 27, 2007 | 06:38 PM
Not necessarily related to overheating, head gasket is leaking the oil in the valley. Its not very common but it does happens.
Old Nov 27, 2007 | 09:17 PM
brolajit's Avatar
my grandpa has a 97 deville has the same o/h issue. he has the northstar. so far he has done crossover gaskets, water pump thermostat head gaskets and fluid change. the guy at the shop found a special kit a machinist out ofpa i think makes. those northstars are excellent motors but they are precision. if you have the headgaskets done and they are not done right it'll keep o/h and burning water. we're on our second rebuild b/c of improper assm. the first gasket set came from cadillac dealer so were gonna try this new set. as far as your starting issue it could be as simple as unplugging the relay and thunk it a couple times to trip it. plug and paly to see if it works.
brushwolf
Dec 1, 2012 07:22 PM
Montek
Apr 5, 2009 06:14 AM
lstone
Automatic Transmissions
Mar 11, 2008 11:46 AM
Jun 27, 2007 09:04 AM
