miss fire
Old 01-22-2009, 01:22 PM
bubblesdad's Avatar
Default miss fire
Hi all new to the forum I have a 2000 Cad Deville a engine code says I had a missfire on number 4 plug,change all the plugs reset the data,still has a miss ,can someone tell me where number4 plug is so I can look farther Thanks Rob
Old 01-23-2009, 12:27 AM
Katzmans Caddy's Avatar
Default RE: miss fire
When you are facing the engine standing at the front of the car, #4 is the second cylinder from your left on front front bank of cylinders. See below:
1 3 5 7
2 4 6 8
Front
A fault coil pack can cause a mis-fire as well. Make sure #4 coil pack connection is good.
Old 01-23-2009, 09:07 AM
bubblesdad's Avatar
Thanks for the reply Took the coil pac off to make sure it was clean reinstalled no differance.I phoned the local cad parts guy $375.00 new or $175.00 one from the junk yard.So I guess thats my next step.
Old 01-23-2009, 09:30 AM
$375 sounds like a lot of money but with a 2000 it would not be out of the ordinary to neednew coil pack atthis time. Why not spend $75 first and get a mechanic torun the diagnosis to be sure.
Old 01-23-2009, 05:13 PM
musique's Avatar
does the engine actually misfire or is it just appearing in information center? It's just unclear by how it's written, and rather than being assumptive...?
Old 01-23-2009, 07:40 PM
bubblesdad's Avatar
the engine does have a miss and has a lack of power,engine code says miss fire on #4 on my code reader
Old 01-23-2009, 09:34 PM
musique's Avatar
no possibility of a dose of bad gas? It can/does happen
Old 11-23-2009, 11:31 PM
kuzoom's Avatar
hi my 2000 sts have same problem on my 5# changed all spark plugs and boots still same if i switch coil pac s what happens i will get #4 miss fire info probbly i m not sure they are same i dont want good coil pac get hurt please help me thank you.
Old 11-24-2009, 08:11 PM
Coil packs do fail, corrosion causes most of them. Unfortuneately one failing and the other failing 3-6 months later is not terriblely uncommon. They are somewhat expensive, you could go the used route "you take it off" types are best deals - 35.00 in my area.
Old 12-13-2009, 11:10 PM
kuzoom's Avatar
if you looking of of front of car
1 3 5 7
2 4 6 8
06-26-2007 04:25 PM
gmburd
05-23-2007 08:34 PM
71STROKERFISH
07-17-2006 11:49 AM
jsjag
06-23-2006 07:19 PM
Quick Reply: miss fire
