Help with 68 DeVille power steer gear box
Old 06-21-2014, 11:36 PM
Michaelwil's Avatar
Default Help with 68 DeVille power steer gear box
Hi Forum,
I am not a mechanic but that has never stopped me having a go my problem is I had to remove my power steer gear box as it was leaking. I have the replacement ready to go in but how do I make sure that both shafts are in the right position on the spindles and the car drives straight. All help appreciated but please give very detailed instructions as I am not a mechanic
Thank
Ozzie Mick
Old 06-22-2014, 07:51 AM
Center steering prior to removing steering box. Install steering box on frame. Steering shaft coupling should only go on one way. Attach shaft to box / rotate steering wheel lock to lock / return back 1/2 as many turns / steering box should be centered and wheel in straight head position. now attach pittman arm wheels should be straight.
Old 06-22-2014, 08:20 AM
Michaelwil's Avatar
Thanks slow roll for your help
jburetz
06-27-2014 10:34 AM
Pontiacyoyo
01-15-2014 03:06 AM
Macko11586
06-16-2009 10:40 AM
wpbrink
07-25-2008 10:49 PM
firstonthebadlist
05-13-2007 09:10 PM
Quick Reply: Help with 68 DeVille power steer gear box
