Fuse location
Old 06-21-2006, 04:39 PM
jpchris's Avatar
Default Fuse location
I have a 99 DeVille and cannot locate the fuse for the ac/heater blower motor. Any suggestions?
Old 06-22-2006, 10:01 PM
FLCaddytech's Avatar
Default RE: Fuse location
Take off the large plastic cover under the hood on the dr side. There are more fuses and relays under there. I think its a Maxi 60 amp.
Old 06-22-2006, 11:37 PM
If you look in your owners manual under fuses it will show you exactly where the fuse is located and what size it is. I think it's on the driver side in the engine compartment fuse box.
Old 06-23-2006, 09:17 PM
jpchris's Avatar
Thanks for your reply, however all the fuses are good. The relay? can't find which one operates the blower motor. Owners manual or the Cadillac manual I purchased does not give this info either.
Old 06-23-2006, 09:18 PM
jpchris's Avatar
Okay found all the fuses and they are good. In looking for the relay, can't find the blower motor one.
Old 06-23-2006, 10:54 PM
I have a question. Have you checked for power and gnd at the blower motor?
99 times out of 100 the blower motor/module is bad.
The new ones have a heat sheild that seems to help them last much longer.
Hope this helps.
Old 06-24-2006, 07:47 PM
jpchris's Avatar
Okay, I tried to find the blower motor module. Juice and ground seems okay. I was also told there is a good chance that you have a bad resistor somewhere. Can't find a resistor either. Any more help. I really appreciate your time.
Joe
Old 06-24-2006, 08:26 PM
Its all in the motor on that one. Its a motor/blower module all in one.
If you have power and grnd at the motor and it does't run, then you found the problem.
Old 06-25-2006, 09:51 AM
jpchris's Avatar
Thanks a lot, that is what I was afraid of. Okay will get a blower tomorrow. thanks again
Joe
dukejet62
10-01-2009 08:51 AM
bellabam
03-24-2008 11:30 AM
bellabam
03-21-2008 08:44 PM
royalet
10-18-2007 09:26 AM
jsjag
02-15-2007 02:17 PM
Quick Reply: Fuse location
