99 Deville rear passenger window ?
Old 06-27-2008, 03:13 PM
99CaddyNH's Avatar
Default 99 Deville rear passenger window ?
My 99 Deville rear passanger window wont go down by the switch or the switch on the drivers side door. All 3 other windows go up and down fine.
Old 06-27-2008, 03:22 PM
Katzmans Caddy's Avatar
Default RE: 99 Deville rear passenger window ?
When you say drivers side do you mean the rear drivers side switch? If not try that switch on the passenger door, I think they plug in to each other. This will isolate the switch.
Also try this, I know it sounds bad, slam the door real hard, then try the switch, sometimes the motor gets stuck.
Lastly check motor for power to contacts, if yes motor is probably no good.
All windows share same maxi fuse so not a fuse.
Old 06-27-2008, 07:17 PM
99CaddyNH's Avatar
My bad I should have said drivers door front. I cant even put down the rear window with the drivers switch or the switch at that actual door itself.
Old 07-22-2008, 01:41 AM
hdryder05's Avatar
05 Deville in which the left rear passengers window ONLY works with the doors open(either one or both). When shut.......nothing. How is this possible? lol! WOW! Thanks, Kevin
Love_tk1
04-02-2012 03:45 AM
mix4
03-13-2010 10:34 AM
TucsonAZ
10-06-2009 04:40 PM
Coupe Evil
03-12-2009 10:22 PM
mrcrx28
03-14-2008 09:04 PM
Quick Reply: 99 Deville rear passenger window ?
