92 deville engine mount questions.....
Old 09-30-2012, 11:43 PM
92 Deville 4.9's Avatar
Default 92 deville engine mount questions.....
I need to replace the front engine mount on my 4.9. I was under the car today looking at it and came up with some questions.
Do the Rad and fans need to come out and will I need to remove the a/c pump or will it move out of the way enough without having to drain the system and pull it?
Any other tips would be appreciated as well. I will be doing it with a jack and stands, no hoist for me.
Old 10-01-2012, 02:46 PM
Anyone?
Old 10-06-2012, 07:49 PM
Done. Its not that bad but time consuming, took about 3 hours.
I ended up pulling the fans and radiator then was able to wiggle the A/C compressor out far enough with a little flexing of the lines to get at the bolts behind it. The a/c bracket had to com off to access the top nut closest to the block on the mount. Then just lifted the engine a little with a jack and out it came.
salem676
04-04-2012 11:02 AM
1996eldawg1
07-16-2009 11:31 PM
Caddy87
Small Block V8s
10-13-2007 04:21 PM
dallac
01-04-2007 10:49 PM
jxsmit
06-29-2006 10:13 PM
Quick Reply: 92 deville engine mount questions.....
