2003 DTS
Old 01-02-2009, 02:50 PM
EAC's Avatar
EAC
EAC is offline
Default 2003 DTS
I have a 2003 DTS (obvious) changed the 2 crank sensors and the tps sensor. Still idles rough and shuts down. Took the car apart to double check the sensors black on bottom grey on top. still throws ses code "idle lower than expected. It's random some times runs fine sometimes horrible. check iac valve seems to be working fine. reset the valve runs great for about half an hour then back to the same thing. Any help would be appreciated!!!!!!
Old 01-03-2009, 09:23 AM
Default RE: 2003 DTS
Check for carbon build up at throttle plate (butterfly), vacuum leak at bottom of the boot that connects intake to crossover, and EGR valve that is not closing.
convertible cadillac
08-09-2015 08:58 PM
jdhinmaine
11-08-2012 08:40 AM
SurferTom
01-22-2011 10:38 PM
Davids DTS
12-02-2007 10:51 AM
John H
10-27-2007 09:23 AM
Quick Reply: 2003 DTS
