2002 DTS Deville Won't Start - Please Help
Old 11-26-2013, 02:04 PM
itisian's Avatar
Exclamation 2002 DTS Deville Won't Start - Please Help
Replaced the starter and battery as both needed replacing - today, went to start the car after finally replacing everything and now it won't start. Clicks, key sometimes locks in the ignition, security system bullsh*t, etc. I'm really looking for some insight here, if anyone knows anything regarding this issue I'd appreciate it greatly...
All electrics come on, car is a 2002 DTS, replaced the speed sensor last week also, front control arms, back tires and brakes, plenum, starter, and battery, all replaced. ANYONE have ANY ideas??
Old 11-27-2013, 02:19 PM
itisian's Avatar
Can someone please help, this is really bothering me and it's going on the 4th week that the car has been in the shop.
Old 11-28-2013, 10:36 AM
Check battery positive cable copper wire for corrosion, positive battery post tended to leak acid. Ground connections are a common cause of electrical troubles.
Old 11-28-2013, 11:05 AM
itisian's Avatar
I'm getting all sorts of codes -- C1232, C1254, B3832, B0249, B0429, P0340, P0385 which I've read is the crankshaft position sensor, and C0710, along with U1000 U1056 U1163 etc... All this because I had the starter replaced and a new battery put in..?
Old 11-28-2013, 11:12 AM
P0385 - crank sensor - will cause stall/no start - need both crank sensors for that
hey were redesigned. need to clear codes then recheck see what comes back. some codes are related to low voltage. Do you have Alldata or FSM disc.?
Old 03-26-2014, 07:04 PM
Cjf93's Avatar
Hey itisian, I have a 2001 dts doing the exact same thing! Where you able to resolve the problem? If so I would greatly appreciate any info you have on solving this problem.
Thanks, cj
mileslong24
12-09-2023 12:35 PM
itisian
12-06-2013 09:20 AM
Lobby Manager
03-30-2009 09:33 PM
KathleenJMartin
10-29-2007 09:07 PM
kkoehler02sts
02-08-2007 12:04 PM
Quick Reply: 2002 DTS Deville Won't Start - Please Help
