Very Low Refrigerent/A/C Compressor Off
Old 05-03-2010, 06:19 AM
leokazoc's Avatar
Default Very Low Refrigerent/A/C Compressor Off
I get this message on my 1994 Cadillac Deville Concours. It has 192000 miles on it and still running strong. The last time the A/C was professionally serviced was at around 93k miles. I really don't know what is wrong. I bought one of those recharging kits and checked it. The pressure gauge said it was fine, but I put it a squirt anyway. So if the freon is fine, I'm really at a lost as to what is wrong. It worked last summer and has just magically stopped working. It gives me this message when I push the AUTO button to start the A/C. Any help would be great.
Old 05-03-2010, 07:04 PM
Check for codes, see FAQ section if you don't know how. You can clear codes with on-board or disconnect battery, clear codes and see if A/C works. ACM monitors A/C compressor cycle time, if it is too quick, will set code and dissable compressor.
Old 05-06-2010, 08:43 AM
Adams' Apple's Avatar
If there are any codes in the system, it will not allow the compressor to engage, which is why it "stopped working". You may have a bad/failed pressure switch/sensor, or any other of many issues. Pull the codes(or get someone to help with that), and we'll see what we can do to help.
Old 05-23-2010, 06:50 PM
Khem's Avatar
Post
I have a 97 Deville and have got the same error message just two weeks ago to find out it was low on refrigerant for you to reset the compressor disconnect the positive battery terminal for a few second , after you connect it turn the AC on check to see if the compressor is engaging if it is then add refrigerant use the can with a guage so it will tell how much you need don t over fill that works for me .
Old 05-23-2010, 07:02 PM
Khem's Avatar
Post White smoke coming from exhaust at cold start
Anyone have any idea what will cause white smoke coming from exhaust at cold start , i want to rule out blown head gasket cause iam not seeing the all the reason . I want to say my air pump is malfunction the engine is not getting enough air , what you think . This is for a 1997 Deville with 114000 miles
Old 05-23-2010, 07:03 PM
Khem's Avatar
Khem;38157]Anyone have any idea what will cause white smoke coming from exhaust at cold start , i want to rule out blown head gasket cause iam not seeing the all the reason . I want to say my air pump is malfunction the engine is not getting enough air , what you think . This is for a 1997 Deville with 114000 miles[/quote]
pmakki
08-07-2009 11:35 AM
Tarrance
10-24-2008 09:09 PM
marcus88
09-15-2008 08:19 AM
bfranc
06-12-2008 10:31 PM
MetalTeK
03-09-2006 05:35 AM
Quick Reply: Very Low Refrigerent/A/C Compressor Off
