Problems with transmission 1995 seville
Old 10-13-2010, 08:27 AM
Adams' Apple's Avatar
Ooops! I just noticed your location in the first post!
Just click on either image for links to larger images.
th_vb2.jpg?t=1286975949
th_vb.jpg?t=1286975949
  #12
Old 09-06-2011, 06:14 AM
Jason's Avatar
Post Parts and labor cost Total?
Originally Posted by slowroll
It is likely broken shift solenoid. GM makes service kit to correct.
I have a 1995 Cadillac Seville STS with the same problem.Thank you.Jason
  #13
Old 09-06-2011, 06:15 AM
Jason's Avatar
How much it costs to fix this problem?
  #14
Old 09-06-2011, 06:17 AM
Jason's Avatar
I am a new member and loking to fix my issues with my STS cadillac with regards to total cost?
  #15
Old 09-09-2011, 07:11 AM
Depends on if you want to do the repair yourself, or have it done.
The solenoid "kit" isn't all that expensive....around $60 or so. Then you have the fluid you'll need to replace.
If you take it to a shop, it will most likely be in the $400 and up range to have this done, IF that's all it needs.
hth
  #16
Old 02-17-2013, 09:56 AM
jsturza01's Avatar
Default Still having problems after changing the shift soleniods
My 95 Eldorado is having the same problem. I ordered the replacement kit and replaced both soleniods along with the bracket as one of them were cracked. After carefully reassembling everything, the car is still not shifting out of 2nd and the service engine light comes on. did we do something wrong, or is there anything else we can check?
  #17
Old 02-18-2013, 06:46 AM
elliot@c2i.net's Avatar
Sorry, I can't help you. When I replaced the solenoids (one were cracked) everything worked out perfect.
Hopefully Adams Apple can help you out...
  #18
Old 06-14-2015, 01:42 PM
95-Eldo's Avatar
Anybody got a diagram of the check ball positions on the 4T80-E
I have developed the same issue as "elliot@c21.net"
Got the repair kit yesterday.
I am a bit Leary of pulling the valve body without having a check ball position diagram.
Are they gonna just fall out?
Trying to get a transmission service manual for her..
I have a 1995 pearl white Eldorado ETC..
Anyone with any info would help...
Thanks....
  #19
Old 06-28-2015, 09:45 PM
The image in my post above shows the checkball locations.
David Darrigo
02-09-2012 10:45 AM
boattail455
03-12-2008 07:01 PM
xquizitone
Automatic Transmissions
09-25-2007 12:31 AM
mixedchick_2005
07-28-2007 12:23 PM
Quick Reply: Problems with transmission 1995 seville
