Catera auto trans
Old 10-02-2007, 09:25 AM
sulup's Avatar
Default Catera auto trans
Hello out there ! Can someone help me on how to check a catera`s trans fluid? And do they need synthetic fluid or regular fluid? Thanks
Old 10-06-2007, 08:18 PM
Default RE: Catera auto trans
You most likely will not be able to check fluid yourself, to check fluid there is a plug in the side of the transmission where the you check fluid level while engine is running and car is level.The cheapest and easy way to have fluid level checked is to have oil changed at Caddy dealer where they top off all fluids and specifficaly request level be checked.As far as does it need changed?, over 50k and in doubt change it, flushing maybe less costly than a service with filter and gasket, but if transmission is not acting right flushing may make it worse so if trans isn't acting right have diagnosed first. NOTE: Catera auto trans is replaced not repaired.GM does not sell parts to rebuild trans in the US, but there maybe aftermarket co.s that do.Hope it helps
Old 01-10-2008, 11:35 AM
sulup's Avatar
Thanks slowroll,sorry it took so long to thank you for your answer and tips. Lou
Cadillac-Catera
07-18-2022 12:40 AM
caddymancan
Automatic Transmissions
05-09-2010 11:12 AM
sailboat mike
08-02-2007 12:24 AM
07-01-2007 02:22 PM
iowavette
04-27-2007 04:16 AM
Quick Reply: Catera auto trans
