Do OEM Tires Go On Custom Rims Too?
Old Jun 12, 2021 | 06:11 AM
oGeesKeeMasK's Avatar
Exclamation Do OEM Tires Go On Custom Rims Too?
I have 18x7.5" 2 crave no.2 rims on my 08 STS V6 Base AWD and have been driving them on what I thought was the most suited wheels for them, 101W rated wheels and I am starting to see how this might have complicated things. Right about now I'm looking to correct this, The OEM rims call for a 99Y tire but I'm not sure what kind go on the custom rims. If you've seen my other posts then you know that I've been complaining about a squeaking noise coming from my calipers, I think that the W rated tire is being incapacitated by the weight of the car when braking and is causing the caliper to squeak (the slide pins grind, even when properly lubed) but before I go and put OEM tires on the custom wheels I want to be sure that they will be the best fit for them too.
DanielAndrew
May 10, 2021 02:50 AM
DanielAndrew
Aug 31, 2020 03:02 AM
carid
Feb 13, 2015 09:52 AM
sickness
Oct 19, 2007 06:16 PM
sickness
Oct 14, 2007 03:48 PM
