18" wheels hit front struts
Old Apr 15, 2007 | 02:15 AM
heatumup's Avatar
Default 18" wheels hit front struts
I have a 2002 dhs with 16" oem wheels . I just bought 2005 18"dts oem wheels,can any body tell me what needs to be added or modified to front for this to work. Any help is appreciated. pat
Old Apr 17, 2007 | 01:00 AM
z32drifter's Avatar
Default RE: 18" wheels hit front struts
Sounds like you need spacers between the wheel and hub. What is the offset of the old wheels VS the new wheels , and width of the wheels.
Old Apr 17, 2007 | 04:19 AM
heatumup's Avatar
I think they are 4.75 offset with 245/50/18 tires. The tire goes on when jacked up, when letting down the body of strut that holds coil lands on top edge of tire about 2" in. The tire is about even with wheel well just like back one. With spacer I don't want wheels sticking out of wells.Was told i'll have to crossreference with salvage yard about2005 DTS to see what is different, strut, steering knuckle, something. People have bigger then this.how is it done. thanks pat
Old Apr 17, 2007 | 11:03 PM
z32drifter's Avatar
Well you only have a few options, you can reduce the diameter of the package using a shorter tire.I don't know the size of your stock tires, so can't say if the new ones are too tall. The other option is to push the wheel out far enough to clear the strut, but you may come out from under the fender. 4.75 is the back spacing, offset is from the center of the wheel. Here's a link to look at tire sizes http://www.miata.net/garage/tirecalc.htmlif you can convert to offset here is a link for that http://marksink.com/tire_wheel_offset/offset.htmlif you look inside the wheels theymay have the size and offsets stamped or cast in the wheel. example 18x8 45 (sometimes offset is shown with ET)
Old Apr 21, 2007 | 03:16 AM
heatumup's Avatar
ended up buying new tires for front 245/45/18. Have to stay within same diameter of original wheels . they look good. thanks for input. pat
grewararpl
Aug 20, 2015 05:24 PM
Bravo410
Automatic Transmissions
May 31, 2012 12:27 AM
turboaz
Jan 24, 2009 12:03 AM
JoeS
Oct 12, 2006 01:49 AM
