Suspension sponsored by Arnott Inc. Discuss anything suspension related within.
05 DeVille Ride Height question
Old Nov 25, 2013 | 12:31 PM
Trent Preuninger's Avatar
Default 05 DeVille Ride Height question
I have an 05 DeVille with of course the ride height air suspension. I am not happy with the height the car rides at. I want to raise it up just a little. I have read that you can adjust some nut or something. Can someone break down in english what to do, if possible. And can you help me locate the ride height sensor? Thank you for your help.
Old Nov 28, 2013 | 11:22 AM
You could try to adjust sensor attached to rear control arm (RT) I think. It won't be much. no adjustment for front. Car has air shocks in rear not air suspension.
Old Nov 29, 2013 | 09:05 AM
SimpsonTruckDriver's Avatar
One option is to replace the air pump with a manual air line. In other words, instead of the factory air pump (which is prone to fail due to excessive use), put a line in that has a valve similar to a tire valve. That way, YOU adjust the ride height with a separate air compressor. When the ride height goes below a certain range, inflate as needed.
Years ago, my dad owned a nice 1984 Buick Riviera, which is similar in body style to the Cadillac Eldorado (but the engine is FAR more reliable than the infamous HT4100 in the Eldo). One of the previous owners did just that: removed air pump and installed the line. When the rear air shocks were low, I took it to the gas station and inflated, problem solved for the time being.
TS
bigbri7870
Cadillac EXT
Jul 9, 2015 12:17 PM
Trent Preuninger
Nov 25, 2013 12:35 PM
Mr69vett
Feb 20, 2011 08:10 PM
sbrice54
May 8, 2009 10:38 PM
mtulman
Jun 3, 2008 03:22 PM
