1993 Cadillac Allante Northstar 295 HP Engine under $100
93 Cadillac Allante Northstar 295 HP Engine - $95 (Longmont, Co.)Date: 2008-05-15, 9:17AM MDT
This is a 46,000 mile Northstar engine that was removed from my 93 Cadillac Allante because of a bad #7 Crankshaft bearing journal. This engine was not used after the noise from the bearing was detected, thus all other internal parts are in great shape. It was replaced by a new engine, then partially disassembled and all parts put in 4 plastic crates for storage. It was my intention to purchase an aftermarket Crankshaft, new bearings and gaskets, and then rebuild this engine for future use. I have since that time sold the car, and no longer have a use for this engine. Local pickup only! Please call 303-709-6490 https://www.cadillacforum.com/upfile...5DAD04C7B9.jpg . |
RE: 1993 Cadillac Allante Northstar 295 HP Engine under $100
10 Attachment(s)
Well, it is my engine now - next winters project - I think turbocharging it will be the way to go.
Great engine - perfectly stored - cylinders as smooth as glass - pistons perfect (except #7 bearing) - timing gears and chains pristine - crankshaft has to go - because of failed bearing - plugs, wires, water pump, everything is there except the starter and engine covers - and I won't need the covers if I turbocharge it. And for far less than a Ben Franklin... Woo Hoo - now the hot rod project can really begin... even I could lift the block Attachment 1853 heads look great and so do the holes in the block - shouldn't have to timesert it... Attachment 1854 Attachment 1855 pistons well protected - and very smooth and clean Attachment 1856 timing gears and chains look great Attachment 1857 bad, bad crankshaft... Attachment 1858 Attachment 1859 bad bearing Attachment 1860 miscellaneous parts and covers Attachment 1861 engine in plastic tubs... Attachment 1862 |
