Paint and Body Tech Looking for some information on body work or a new paint job? Talk about it here!
Install New Windshield 57 Coupe
Old Aug 18, 2021 | 09:14 PM
Fred Neitzel's Avatar
Default Install New Windshield 57 Coupe
Hi,
I purchased a 57 Coupe de Ville in 2014. Six years later I'm close to the finish line. But not really. I'm in the process of installing a new windshield. I can't seem to get the lower part of the windshield close enough to the pinch weld to pull the string get the seal over the edge and onto the pinch weld. I went by the instructions and started to pull string at the bottom center of the new windshield. Did not work. It's like the seal is too fat. Should I try and start the string pull at the top center of the windshield?
The new glass measures correctly comparing to my old removed one. I just can't get the bottom to push in close enough to the pinch weld.. it's pushing up tight against the top header?
Anybody have any special secrets to get a windshield set into a coupe opening?
Thanks for any help.
Fred
Old Mar 21, 2023 | 01:54 AM
Clare@'s Avatar
I think you can try and start the string pull at the top center of the windshield.
Old Feb 25, 2026 | 11:57 AM
jackdennis's Avatar
Originally Posted by Fred Neitzel
Hi,
The new glass measures correctly comparing to my old removed one. I just can’t get the bottom to push in close enough to the pinch weld, and I’m wondering what to expect during windshield replacement because it’s pushing up tight against the top header.
Fred
The glass is sitting too high. Push it down firmly while a helper presses inward from outside. Use plenty of lubricant and warm the gasket if it’s stiff. Then pull the rope slowly from the bottom center toward the corners.
mikedunbar
Oct 24, 2011 09:23 AM
allciuyt
May 12, 2011 04:28 AM
75 Coupe
Dec 25, 2008 05:27 PM
Brent
Apr 1, 2008 03:01 AM
lempoz
Dec 12, 2006 06:25 PM
