Solar Generator for your Cadillac
Ideal for camping or emergency power outages, the
Sun Power Port is a portable generator that when used to its full potential will pay for itself in less than two years. In one day of full sunshine, the solar panel easily charges the 12 volt (standard automobile) battery. An inverter changes the DC current to AC. From there the electrical energy is easily accessible to most standard 110 volt small appliances used in North America. What are the advantages of a solar generator? If you don't know, check out sunpowerport.com. The featured generator will run most small electrical appliances. It is great for camping or emergency backup. No noise. No fumes. For more details see http://www.sunpowerport.com |
Originally Posted by dextercath96
(Post 36275)
Sun Power Port is a portable generator that when used to its full potential will pay for itself in less than two years. In one day of full sunshine, the solar panel easily charges the 12 volt (standard automobile) battery. An inverter changes the DC current to AC. From there the electrical energy is easily accessible to most standard 110 volt small appliances used in North America. What are the advantages of a solar generator? If you don't know, check out sunpowerport.com. The featured generator will run most small electrical appliances. It is great for camping or emergency backup. No noise. No fumes. For more details see http://www.sunpowerport.com The Sun Power Port: Ideal for camping or emergency power outages, the Sun Power Port is a portable generator that when used to its full potential will pay for itself in less than two years. In one day of full sunshine, the solar panel easily charges the 12 volt (standard automobile) battery. An inverter changes the DC current to AC. From there the electrical energy is easily accessible to most standard 110 volt small appliances used in North America. On a full charge, without the sun, the battery has enough power to run and charge a laptop computer for about three hours, a 19" television for over an hour or a twenty watt light for about ten hours. Next time the power goes out, read in silence, listen to music, surf the Internet while the Sun Power Port provides a clean energy source. Configurations: Solar panel:28W full tempered glass plate Maintenance-free lead-acid battery:12V12AH Charge-discharge controller 5A with the protection of over- charge, over-discharge, short circuit and overload Charge for about 8 hours to provide 12V*1A added power to fully charge the power boxes Technical parameters: DC output:12V、6V、4.5V AC output:110v/50Hz - can support any electrical device in this range (fans, lights, cell phones, digital products, etc.) Over discharge protection:10.8V; resumption output:12.5V Over charged protection:14.5V Temperature use range:-4 degrees F - 140 degrees F (-20℃--60℃) Humidity use range:10%--80% Maintenance: Battery needs to be fully charged and discharged at least once per year MSRP: $695.00 that is pricey! my $300 Toshiba nb205 operates over 9 hrs on its battery which i often keep trickle charged with a solar panel that i got at the auto parts store for $70. the Toshiba USB ports power: the led light, a little fan, the computer and internet, the "magicjack" for landphone, skype video phone, the cell phone charger, bluetooth devices, run the free movies and TV shows in HULU, play music, play the USB external DVD player, operates the telescope. i'm still expanding the toshiba ... a 3G network MiFi is probably next in the agenda, waiting on the phone company wars to bleed the prices down. . |
